H/C swap, possible problem?
I just lowered my oil pan about a 1/2" but the front of the car was raised, so some oil (maybe half a cup) spilled out the back, and possibly into the bell housing. It's hard to say if any got in there. Any advice??
There are two metal little inspection covers at the bottom of the bellhousing. Pop them out with the screw driver and see if any oil comes out. If there's still some oil left in there, I don't imagine that it would be that big of a deal. The underside of the car will be oily for probably the next 6 months though.
Originally Posted by ashade98
Any advice??
Sorry, I should have been more specific. If you're an A4, the method I described is sufficient. M6 guys, I'm not sure about. I know the LT1s don't even have the bottom half of the bellhousing on their A4s, just a piece of plastic (inspection cover), I'm assuming stuff getting up inside the bellhousing is not detrimental to the mechanics of it.
Do you mean the two plastic inspection plates that bolt near the back of the oil pan w/a 10 mm bolt?
They cover the lower front of the bellhousing? This is how the oil would have gotten in there.
They were off because they are in the way a little for the oil pan bolt.
I'm just going to lower the front of the car before I button up oil pan and the inspection plates and see if anything drips out. What'd ya think??
the m6 has a slot on the bottom of the tranny for drainage,the oil will not hurt anything running down the inside,unless it was sprayed in there it wont hurt a thing,the clutch assembly will be untouched by it,just forget about it and it will drain out by itself when the car is leveled.
That's good news. I think I'll spray a little brake cleaner down into the bellhousing through the inspection plates to loosen up the oil before I button it up. That should help get most of it outa there! Thanks-
Anybody else have input!
