Long in the Tooth
Long in the Tooth
Ok guys want your opinion on a cam install.I have an 01 m6 z with 48000+ on the clock.When do you think it becomes a mute point to add any internal parts .In otherwords is this millage "long in the tooth" or should I wait till a total rebuild?I dont drive it during the week anymore inlight I recieved a company truck so the miles will be limited.Thanks for any response.
you are perfectly fine to do a cam install or anything else you might want to do for that point. 48,000 miles is nothing! I finally did my cam install at 73,000 and i know of quite a few people on here that have done cam installs with well over 100,000 miles. I'm sure they will chime in!
Brent
Brent
It doesn't matter how many miles you have on the motor, what matters is if that motor is healthy.
My advice before major internal mod is to do a compresssion and leakdown test to know the status of your motor. Based on the results, you then have a clear picture of how to proceed.
Thanks for the info guys.I guess Ill start the insane process of cam choice.Its crazy with all the configurations out there.Ill start the fourm search asap!
