good list for a 383?
Possible Scammer - Buyer Beware - Issues Unresolved
i posted this in the wrong section earlier, so if you are seeing this again sorry
i'm trying to build a BUDGET 383 stroker, how does this parts list look, anything missing?
eagle 4" crank
callies 6.125" H beam rods
diamond 3.905 -7cc 383 pistons
Diamond Pro-Select Piston Rings, 3.905 Bore, 1.5 - 1.5 - 3.0 mm
ARP pro rod bolts
clevite H rod and maiin bearing
various gaskets
look good? can this be done on the stock block?
eagle 4" crank
ARP pro rod bolts
various gaskets
if your stock block is in good condition - then you should be able to do a .005 hone on it and be good - along with any other machining required for clearance.
i'd add arp head bolts/studs.
