Cams Cams Cams
Old 01-30-2006, 08:09 PM
Charlie@LsXperts's Avatar
Default Cams Cams Cams
hey i want to do a cam swap but im not gonna do oil pump, heads, lifters or pushrods its all gonna be stock except the cam i put in. I was just curious if this was a bad idea or if there was a small enough grind i could use with stock valvetrain. Any input??? how bout some cam numbers that will work for this setup, again all im changin is the cam if wise.?.?.?
Old 01-30-2006, 09:09 PM
jrp
SN95 Director
jrp's Avatar
dont bother...
bare minimum is cam, springs, and PR. and if all you've got is exhaust i'd complete your bolt ons first.
Old 01-30-2006, 09:42 PM
WsSickLs6's Avatar
yeah, don't bother going for a cam that is small enough to work on stock valvetrain...It's not going to make much, if any, difference...Do your bolt ons, and you'll find the power you are looking for
