Alrighty...need a little help
Well normally I would not be making this thread if the search wasnt broken, but it is, and I am. My goals are a VERY streetable H/C car that can make 420-430ish RWHP while still making low end torque and good power under the curve. Im more worried about having it run smoothly than achieving power everywhere. I am more worried about achieving power everywhere than making the 430 RWHP mark. So it goes: driveablity>power throughout>peak numbers.
Ive done a decent amount of research and think that a nice set of PRC's heads might be in my future. Which ones im not sure. I havent ruled our Patriots either. The PRC's CNC'd LS6 heads and 5.3 Stage 1.5 both look like a pretty nice bang for your buck. I like the Dart Stage 2s from PRC, but I wonder if the large 237cc(?) runner might be too much for my application. The PP Stage 2 LS6 seem nice with a nice price tag with them, and plus it comes with bolts and head gaskets which is a plus. Kinda more towards the PRC 5.3's as we speak, but that my change. Your thoughts are welcome.
**Just confirmed that the PRC Darts are infact 1599 for both heads(lol), im kinda liking that a bit.
Onto the cam. The cam I have in there now is too small to make those kinds of numbers. But im leary of going too big. I kind of like the Futural F6 (226"/230" .575"/.595" 114LSA) or F11 (228"/230" .576"/.595" 114LSA). Ive heard a little more positive from the F11 so im leaning towards it, however the F13 (230"/232" .595"/.585" 114LSA) has a even more positive feedback. Do you guys think an F13 can be tuned to drive fairly tame (no surging and bucking at low RPMs) or would an F11 sized cam yeild better driveability without too much loss. Most of these 430 RWHP numbers im seeing are bigger than the ones ive listed. Dont forget Id like to have power everywhere(Doesnt everyone ). Any other cam suggestions?
Would I ABSOLUTLY need an LS6 oil pump? I have a newer oil pump installed that has about 18k miles on it, that was on my buddys 02 SS. I would get an LS2 timing chain.
Is there anywhere to get a cheap set of centerbolt valve covers (with coils if needed)? Damn 98 heads, if I got a set of heads Im assuming that they will most likely be center bolt.
No, I dont have an LS6 intake, but yes Im planning on getting one. I have the rest of the supporting mods. Any comments on any part of my essay would be appreciated. Thanks!
Chris
Chris
You're not going to make 420+ and have good power down low and good driveability. For good low end torque you'll need to close the intake valve earlier and therefor give up some peak HP. A good tune will make the cams you've listed very driveable but very rare to have no low rpm surge or bucking.
Go a little smaller with a little less overlap, with good heads you'll get close to 400, have better low end, and be very driveable.
Originally Posted by Nittany_marine
I was thinking along your lines as well....Look at my sig, and you'll see what I went with. She rund great, and is daily driven. Also, she just shreds the tires down low, and is a monster out of the hole.
Thanks for the replys guys...keep em comin.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by orangeapeel
Junk yard will be your friend on this. I have not seen anyone offering a perimeter bolt style head for *new* aftermarket. head castings that you would be looking for would be 853, 241, 243, 317 (truck 6.0l head)....
I looked up the G5x3 on google, and something like 236/242 .590/.609 114LSA . Seems a little big, but from the limited amount of searching i can do, it seems that people think it still has great drivability for the amount of power it makes. But like I said, I would rather risk loosing 10-15 RWHP if it meant it ran a lot smoother.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
actually that sounds right with the cam size. As far as finding the stuff at the junkyard.....they will have that type of stuff pulled off and tossed in bins. I would just sit down with a metroplex phone book and call all the junkyards and ask. I got some good stuff that i thought that I would never find that way. plus the worst they can say is no. food for thought though.
Very true...I will probably do that if I do decide to pull the trigger. Ive seen some centerbolt valvecovers on ebay but none of them come with coils. Also saw another thread about problems using 99+ coils with a 98 PCM/wiring. Are the connectors different/incompatible? Are the 99+ coils themselves incompatible?
BTW, patriot does sell a set of perimeter bolt heads, for the stage II LS1 heads, as an option. This would solve my problem there, but are those heads enough for what I am looking for?
yeah they are probably cnc'd and fully loaded. I had no idea that they had those! that is actually really good to know. I do have a set of 853 centerbolt style heads that i would give up for about 100 bucks.
