hows this set up sound?
afr 205 heads,fast 90/90,magic stick cam ,42lb injectors,lt headers,yank pt4400 converter,moser 12 with 3:73 gears.do u guys think the 3:73's will be a good match with the converter and the cam?or is the gear too much or too little .anyone have a similar setup?thanks
i'd run a 4.10 gear with that, if you are going for times on the track.
otherwise it sounds good - should fly. i'd call TSP and talk to them about what set of heads they've had best luck with when using the MS3 tho - just a thought.
I will let you know how it runs in about a week or so! Jason recommended the CNC'd Darts to me so I will suggest the same to you. They flow excellent #'s and give you more PTV clearance than the milled AFR's. Not to mention , they are a lot cheaper
