started head/cam swap
Old 02-04-2006, 10:47 PM
cowboysfan's Avatar
Default started head/cam swap
finally started my swap, got my heads/cam and everything in between left. so far it has not been as bad as I thought it would, just takes time that all. here r some pics.
fuerzaws6
Attached Thumbnails started head/cam swap-dsc00219.jpg   started head/cam swap-dsc00193.jpg   started head/cam swap-dsc00261.jpg   started head/cam swap-dsc00262.jpg   started head/cam swap-dsc00267.jpg
Old 02-04-2006, 10:54 PM
618HAWK's Avatar
Look like fun....What heads are you using?
Old 02-04-2006, 11:41 PM
cowboysfan's Avatar
Patriot Performance ls6 2.02/1.57 59cc.
I'm enjoying it!!!!!
fuerzaws6
Old 02-05-2006, 07:27 AM
Black Z/28's Avatar
Yeah, I had some 'fun' disassembling mine too. By when I started putting everyting back together that's when I went through a whole different set of emotions- like, stress, anger, fear...
Old 02-05-2006, 08:42 AM
PREDATOR-Z's Avatar
What cam are you throwing in? and are you changing lifters??
Old 02-05-2006, 10:02 PM
cowboysfan's Avatar
Comp Cam 231/237 .589/.595 lsa112+4.
new lifters r Comp Cam 850-16.
pulled heads/cam today. need to remove oil pump. any suggestions on how to remove it? I have done some research, but just wanted some feed back on those of you that have actually r/r it.
thanks
fuerzaws6
Old 02-05-2006, 10:59 PM
SSU's Drunk Typing Whore
Lithium's Avatar
There is some good info on how to remove the oil pan in my thread
https://ls1tech.com/forums/generation-iii-internal-engine/434219-i-reallllly-f-ed-up-now.html
Think its like page 2 or 3...
Basically it was not that bad, I mean it sucked...but very doable.
Old 02-06-2006, 10:07 PM
cowboysfan's Avatar
well got head/cam out, no problems just a minor set back, dropped lifter cradle bolt in cam journal. did get it out w/ finger magnet. installed cam/chain. anybody know where I can find how to port oil pump? I think I have read it hear, some where. problems w/ search here. heres some pics.
fuerzaws6
Attached Thumbnails started head/cam swap-dsc00306.jpg   started head/cam swap-dsc00307.jpg   started head/cam swap-dsc00308.jpg   started head/cam swap-dsc00309.jpg
Old 02-11-2006, 09:27 PM
cowboysfan's Avatar
finally got cam/chain/oil pump bolted, also cover and oil pan bolted, checked ptv clearance and that too checked good so next is my heads. cant wait to get her started.
fuerzaws6
Old 03-13-2006, 11:07 AM
cowboysfan's Avatar
well did get it done, had a detour to attend. well I had it dyno'd this past friday and it made 417 rwhp, 390 rwtq. sounds
fuerzaws6
