Cam selection: 5.3's milled for 11:1 (.03), 3500 stall, 3.23 gear
Cam selection: 5.3's milled for 11:1, 3500 stall, 3.23 gear
Looking for the strongest NA cam I can find to match up with these other parts in my A4 car. I know the cam will have to be on the smaller side because the heads are milled. Also, please let me know how 3.73s would perform with the cam in question.......thanks
5.3s should only need about .010" to bump an otherwise stock LS1 to 11:1. The factory 5.3 chambers are 61.3cc vs 66.7 for the 5.7 LS1 heads.
I'm not trying to bust your chops about your heads I'm trying to understand exatly what you have. I have an LS1 that I'm building a set of 5.3s with 2.02s and I'll be running a Futral Motorsports F14. My 5.3 heads were millied about .007"
You need to find out how much they're really milled. like I said, 11:1 on 5.3 heads doesn't take much milling, but the valves are .030" lower already so cam choice is important.
