coil pack brackets ls1 to ls6 swap
Old 02-07-2006, 08:32 PM
dnkynrbk's Avatar
Default coil pack brackets ls1 to ls6 swap
Tell me im smoking crack here I just took my coils off my 98 valve covers got a set of 6.0 coil brackets went to put the coils on the bracks and the holes dont line up and the 98 coils are more rounded then the newer coils is this correct. Anyone have any ideas should I just get a newer set of coils and will they work with my computer. thanks guys
Old 02-08-2006, 10:20 AM
dnkynrbk's Avatar
is it worth or can you just get newer coil packs from a slavage yard and will they plug in to my harness
Old 02-08-2006, 11:25 AM
joelvette's Avatar
the 6.0 valve covers have more and different bosses on them for the 6.0 coil brackets otherwise the valve covers are the same for center bolt heads. dont know if they made any 6.0 valve covers with perimeter bolt holes. the coils themselves are supposed to have a stronger spark. you will need to check if the coil harness plugs into the engine harness. hope this helps more than confuses. joel
Old 02-08-2006, 11:54 AM
SUX2BU's Avatar
why did you but 6.0 coil brackets? those are for 6.0 coils. you have LS1 coils. but LS1 99 and up coil brackets.
Old 02-10-2006, 12:00 PM
dnkynrbk's Avatar
everyone told me they were interchangable oh well leson learned
Quick Reply: coil pack brackets ls1 to ls6 swap
