what else do i need?
what else will i need with a TSP magic stick to make it work properly and safely? thanks.
EDIT: does the kit come with just the cam or is somthing else included.(ive never bought a cam before)
I'd run either those PRC or Patriot Gold springs and be sure to measure for correct pushrod length. After that it is really up to you, some people use stock timing chains some don't, most people change oil pumps while they are in there and some people even change rod bolts if they plan on spinning it pretty high.
