Milling heads and safe p/v clearance.
I've got stock ported LS1 heads with 5.7 MLS gaskets and a Futral Motorsports F14-114 cam(.59855 lift) and H.S. 1.7 Roller Rockers.
How much should I mill off the heads and still have no p/v issues? Also what length push rod should I use?
Thanks,
Ted Z
Thanks,
Ted Z
I would ask Futral about milling. They can give some good targets. I think .025" is a safe amount. I know there are few guys on here running more.
For pushrods there is a calculator on here somewhere. You need to know your cam base circle and how much milling you are doing in order to calculate pushrod lenght.
