3.905 or 3.910?
Old 02-09-2006, 05:55 PM
blazerls1's Avatar
Default 3.905 or 3.910?
I need some advice.I'm about to buy a ls6 bare block to build a 383.Would it be better to run a 3.905 piston or a 3.910 piston?I never see anyone talking about the 3.910 bore size.Can a ls6 block be taken to that bore safely?I would fine with the 3.905 bore,just read where mahle offers the 3.910..also,anyone running mahle pistons?Any help will be appreciated..Scott
Old 02-09-2006, 06:33 PM
Flow Wizard
Tony Mamo @ AFR's Avatar
The less material removed the better (THIN sleeves)
If you can get a perfectly straight bore at 3.905 that is undoubtedly a better way to go....Leave yourself some room for a "clean-up" down the road. You never know....
Tony
Old 02-09-2006, 07:17 PM
blazerls1's Avatar
Thanks tony,I was leaning towards the 3.905 bore because I can get the JE pistons in that size.Nothing against mahle,i just know more about je's..
Old 02-09-2006, 08:24 PM
DanZ28's Avatar
I think Diamond, JE, Ross, Lunati, Weisco and probably others have 3.905 size pistons. I agree with Tony as well. Is this a new block or a used block? If used, then definately pay to get it machined to 3.905. If new, I would go with stock bore size and save you the $$ for machine work, your only talking maybe 1 CI. In fact you might want to price it out, a new block may come out cheaper than a used one plus machine work costs for boring .
Dan
Old 02-10-2006, 12:02 AM
racecar's Avatar
Go with 3.905 now. A few years when you want to rebuild, you can rehone it to 3.910.
Old 02-10-2006, 12:14 AM
MountainMotor's Avatar
I agree with everyone else that the 3.905 bore would probably be the better choice. You still have a clean-up later on down the road. I agree with DanZ28, that it might be cheaper to get a new one and save money. I was going to get some work done on my block but found it was cheaper to get a new one so I think I'm going that route soon.
Quick Reply: 3.905 or 3.910?
