torque on rocker arms????
Old 02-09-2006, 08:46 PM
hardtopz28's Avatar
Default torque on rocker arms????
what am i suppose to torque the rocker arms to on stock ls1 heads
thanks for any input
Old 02-09-2006, 09:00 PM
dyls1's Avatar
22 foot pounds iirc, and the cam shouldn't be trying to open the valve.
Old 02-09-2006, 09:51 PM
LS1TECH.com Sponsor
WS6store.com's Avatar
Per GM SI website:
1) Install the rocker arms and bolts.
2) Rotate the crankshaft until the number one piston is at top dead center (TDC) of the compression stroke. In this position, cylinder number one rocker arms will be off lobe lift , and the crankshaft sprocket key will be at the 1:30 position. The engine firing order is 1,8,7,2,6,5,4,3. Cylinders 1,3,5, and 7 are left bank. Cylinder 2,4,6, and 8 are right bank
3) With the engine in the number one firing position, tighten the following valve rocker arm bolts:
• Tighten the exhaust valve rocker arm bolts 1,2,7, and 8 to 30 N·m (22 lb ft).
• Tighten the intake valve rocker arm bolts 1,3,4, and 5 to 30 N·m (22 lb ft).
4) Rotate the crankshaft 360 degrees
5) Tighten the following valve rocker arm bolts:
• Tighten the exhaust valve rocker arm bolts 3,4,5, and 6 to 30 N·m (22 lb ft).
• Tighten the intake valve rocker arm bolts 2,6,7, and 8 to 30 N·m (22 lb ft).
__________________
WS6Store.com | Sales@WS6store.com
F-Body Performance Parts | 1-877-232-9701
Old 02-15-2006, 10:05 PM
SideStep's Avatar
But the crank key-way is at 1:30 twice... once when the sprockets are dot to dot and then again when the dots are both at 12:00... Which of these positions is cylinder 1 at TDC for the firing stroke???
Old 02-16-2006, 07:15 AM
vettenuts's Avatar
Rotate to TDC watching the #1 intake close and then the piston come up to the top. That is "TDC".
