TR230/236 cam?
Old 02-11-2006, 11:04 AM
00badbird's Avatar
Default TR230/236 cam?
Was wondering if any of you guys have had any experience or have heard anything about this cam from thunder racing?
TR230/236
.590/.598 112 LSA
2400-6800 power band
thanks,
jay
Old 02-11-2006, 11:58 AM
7 Second Club
ty_ty13's Avatar
i have it.... i like it... make sure you get a tune
i made 399rwhp with all the bolt ons and a 12bolt with 4.10 gears and a ss4000e converter.
Old 02-11-2006, 12:42 PM
WKMCD's Avatar
I run a 230-236 Comp XE-R 112 0 advance with .598 .610. All bolt on C5 with a ported FAST 90/LS2 TB setup. This is with PRC 2.5R's. SD tune by Phil at ProStreet MotorSports. I'm running 460-470RWHP and drivability is great. I've got my rev limited set at 6600.
Old 02-11-2006, 12:49 PM
00badbird's Avatar
Thanks for the info guys, I will be running this with Pacesetter Longtubes, borla exhaust, LS6 intake, poted throttle body, 4:10 gears. Oh and the car is an M6. I am lookin to make a little over 400 to the wheels. Think its possible with a good tune?
And how does this cam react with nitrous?
Old 02-11-2006, 01:15 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Cam will work great with Nitrous.
8banger's Avatar
Definitely possible. Awesome with nitrous, because it's a wide enough traditional split, so it would respond well. I was considering that cam and ended up ordering the TRak cam, it's smaller duration (231/234 or 233/235, depending on who you listen to), but the lift is higher (.644"/.598"), easily outperforms the 230/236, and is probably one of the most well balanced cams out there. It's put down about 490rwhp with AFR's and FAST90 setups. Badass. Just make sure to get dual springs.
Old 02-11-2006, 07:20 PM
black01_WS6's Avatar
that would be a good cam for nitrous, I have a similar type of cam 232/234 595/598 on a 112. I made 423rwhp and 381rwtq with a excelent tune.
Old 02-12-2006, 10:11 AM
00badbird's Avatar
what are your 1/4 mile passes with this and similiar cams?
thanks for the info guys
Old 02-12-2006, 10:24 AM
just-a-z's Avatar
I had a 230/236 592/602 114+4 LSA and made 390rwhp with bolt-ons and through a 12bolt and a Yank SS 3600. It was an awesome cam only setup
Old 02-12-2006, 03:44 PM
00badbird's Avatar
good to hear cause this is gonna be a cam only for the most part, I may spray it from time to time........
thanks again for the info fellas
Old 02-12-2006, 06:17 PM
FACE's Avatar
With a 230/236 .570/.578 114 +4 and AS stage II heads I dynoed 397/378 through 4.10's and a Yank SS4400. So far have run a 11.0 @ 120. The car has high 10's in it once I get rid of my wheelhop issue.
Old 02-14-2006, 09:34 PM
00badbird's Avatar
I am gonna get the car tuned, but is it ok to drive the car untuned for a week or so without any problems with and M6?
thanks,
jay
Old 02-14-2006, 09:44 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Yeah, I went half a year untuned on heads and cam and exhaust....you should be fine.
