Rod Bolt Hitting Oil Pan F-Body !!!!!!
Im building a LS2 418 for my TransAm and as i was putting the oil pan on i noticed that the ARP L19 rod bolt is hitting the f-body oil pan at the front of the engine were the little dent is ,This is to clear the factory rod bolt , and i have the oil pan gasket on also, What do i need to do? grind the bolt head or the oil pan, The only thing about grinding the pan is that i dont think it is thick anough with out cuttung threw the pan , I have Eagle 6.125 rods & 4.100 Eagle crank ,05 LS2 aluminum 4.030" ,how much clearance do i need between the bolt and pan.
is this whats every body with a stroker in a f-body doing ? ,I have a tig welder at work ,I didnt want to grind the bolt nether because it will throw off the balance job , But there is very little room between the pan and the frame .I guess ill grind till it clears or cuts thew and ill just build it up and hope it clears the frame
You could cut out a small rectangular section of the pan and weld a "cover" panel onto the outside of the pan. That should give you enough clearance and eliminate the possibility of the pan cracking from being too thin.
This is what happened to me last night
easy fix I guess......... just another hold up I guess..... DAMN my car is loud
buddys 408 with grp aluminum rods hit and the motor wouldnt turn over.
id grind the bolt... but thats just me.
welding the pan is a good idea. grind away for days if you need to.
must be a good weld, or youll have oil seeping out of it. then youll have to take the pan off and clean it before welding.
oil and welding dont mix.
good luck.
good luck.
good luck.
good luck.
Grind the pan!
Or just to add some humor, bolt it up and start the bitch up! It'll clear itself out!
Originally Posted by Mean Green z28
People spend all that time and money carefully balancing and blueprinting engines for what? You wanna recommend grinding the bolt down and throwing the whole balance off?
Grind the pan!
Grind the pan!
id grind the bolt.... didnt say anyone else had to.
matter of preference.
