Backfire thru exhaust after header install
After installing headers, catted y and TSP catback the car backfires thru the exhaust when I shift (M6). It gets worse when the weather is cold and it only does it under heavy throttle, if I drive normal it doesn't backfire. Anyone else have this problem?
My car backfires all the time, in between shifts on the street around 3500 or so and even after tossing it in neutral after a track run at the traps through 4th around 6600. But the strange thing is it doesn't do this between shifts at high RPM's while racing.
My Fiance thinks it sounds cool but I think it sounds likea jalopy! Funny how it doesn't do this with his PCM but it does with mine. And they've tuned the car but there is unspent fuel that's causing this.
I cannot recall this until I added headers, hell it will even create a few tiny backfires or subtle pops after starting it while it's running. I do think it got worse after my cam went in though. You can smell unburnt gas with cams and ORY's so your issue can be a tuning issue. Car is getting more air so with more power can cause the PCM to start tossing fuel thinking it's a bit more lean. Mine is obviously dumping more fuel somewhere with the RPM band and it wasn't dyno tuned with a wideband.............and getting the guys to do this is nearly impossible they don't think it's bad or annoying like I do
Weird **** but the car runs good #'s and traps nicely.
I think your right, it might need to be tuned. I also have an ls6 intake, port tb & maf so it's defenitly getting more air in and out now. I've been wanting to do a heads and cam so I'll wait and see if that happens before spending the money on a tune.
Sounds great I think; it happens when the engine decelerates rapidly, especially when still cold. Mine was worse when I just had the Loudmouth, and got better after I added LTs and Cats. I have a 160* stat so I hear it all the time, but I love it. But I goose the throttle for hard down-shifting to take it easy on the clutch and help the synch. (This is normal behavior for LM owners, right?)
Try to visualize riding behind you at night and those pops are jets of flame...
...anyone see that mod where you stick spark plugs in the exhaust tips, and then pull a coil wire from #7 to dump raw gas down the exhaust and ignite it at the tail pipe. Dumb, I know; not advocating it, just providing an example of someone else obviously over the top, so you'll think I'm normal
Seriously, you might be a little rich, but I do like the sound...
