59cc heads vs. 64cc Patriot Heads
Hey everyone,
I'm just about to purchase a set of new heads, ls6 patriot heads stage 2 and was wondering the advantages of 59cc heads vs. 64cc heads. Just flow? Compression? They're the same price; I'm looking to buy from a member who never installed his set and is sending them to Gunnar for a quick check-up, and are 59cc.
I'm most likely going for a tsp torquer v2 cam, F13 or similar, less than .600 lift.
*edit* also, what cams will clear the 59cc head?
Thanks.
Thanks.
Just a heads up, I have an F13 and I've been told a 59 cc head may or may not clear. They definitely need to be clayed before install and there's no guarantee they will clear. (This is from Futral)
Originally Posted by Rescue Ranger
How will the higher combustion effect engine wear? How can I adjust compression safely w/ gaskets? Sorry for all the extra questions, this is a big purchase for me
...And you probably won't be able to run regular grade gasoline. But no one runs regular in these anyway, right?
It's a big purchase for anyone. So don't be scared to ask questions. And there are no dumb question when learning something new.
Originally Posted by TAF Motorsports
The chambers are welded up then heat treated. they start out as Raw "Lq9" castings.
The LQ9 is the 6.0 head it has a vol. of 71.06. you are right about the LS1.The 5.3 is the LM4/LM7 it has a vol. of 61.15. The LS6 has a vol. of 64.45. These are the stock ComChmbr(cc) vol.
