easy cam questions
easy cam questions
i have 6.0 in a rcsb with a 221/221 cam it is 114+4 i have a stock timing chain is there a way to advance retard with stock timing chain. I would like to move my powerband up in the rpm range? what can i do besides swaping for a new cam or buying an adjustable timing chain.
thanks
thanks
LS1 Tech Administrator
Get the Moroso offset bushing set. You drill out the dowell pin hole on the cam sproket and insert a bushing with the offset that represents the advance or retard that you want. It's an old school approach, but it works. Otherwise, buy a Comp adjustable timing set and just use the cam sproket on your stock chain.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Originally Posted by tdogg5.3
...advance retard with stock timing chain. I would like to move my powerband up in the rpm range? what can i do besides swaping for a new cam or buying an adjustable timing chain.
thanks
thanks
I did this bushing mod and it is very simple if you use a drill press. If I remember correctly I did not drill hole completely thru cam sprocket, I drilled hole so bushing set slightly below flush.
