compression change?
compression change?
hey guys... what kind of compression can i get down to from 12:1 WITH AFR 225 heads.... currently have afr 205 heads unported... btw this is for a friend of mine looking to go turbo and is n/a right now.....
well how bout this is there a way to go from 12:1 to under 10:1 to run a turbo without changing pistons... what is on the car now is a forged 346 and afr 205 heads compression is 12:1 as stated... dont know what gasket etc...
ill find out more and let you know... i think he has new rods and pistons not crank... must be domes, ill check. although builder said it was possible to switch to the 225 heads and run 12 psi... just trying to verify that... what would compression have to be for 12psi on 93 octane???
