how much milling?
Old 02-26-2006, 09:33 AM
Public Enemy's Avatar
Default how much milling?
hi guys, i am in process to port&polish my stock 241 heads locally cause i dont have a budget to buy new heads.. it will cost me only around 600 dollars to port and polish locally
my question is how much milling do i need to make the compression ratio around 10.5:1 with cometic 0.40 gaskets? btw my camshaft is a 220/220 115 lsa cause my car is daily driver and i use 91 octane so i dont want more than 10.5:1 compression ratio.
thanks
Old 02-26-2006, 12:47 PM
greenwood's Avatar
the chamber is 67cc as cast after a vj maby 68 after mill 64 will be ok if it was mine
maby 62 cc woulde be better so .005-.006 per cc .025 will be good if you want 64 cc
