AFR, ETP, etc vs. PRC (Texas Speed) w/ LS6 Cam...??
Old 02-26-2006, 06:54 PM
Closer_2001's Avatar
Default AFR, ETP, etc vs. PRC (Texas Speed) w/ LS6 Cam...??
Looking for your input to a specific question:
If I am going to stay with the stock 02-up LS6 Cam (.547/.550 Lift)
Does it make more sense to have better mid lift numbers assuming a comparable port velocity?
Comparing the 205 cc AFR head to the PRC CNCd LS6 Head.
PRC at .500 Lift = 287 CFM
AFR at .500 Lift = 281 CFM
AFRs cost considerably more and granted have better springs, etc. I am planning to swap my Sodium Valves to the PRCs so it really doesn't matter to me. The PRC #s are done using stock valves.
Your comments are welcomed...
Why LS6 cam?
This is going in a CTS-V and I like it to be docile when carrying family and clients. Other mods include LPE CAI, Kooks LT Headers, Hi-Flow Cats, Stock Cat-Back and Tuning.
I had a G5X-3 in a GTO...which was nasty, but a little much with customers in the car.
Future mod beyond the heads might be a Magnuson.
E
Old 02-26-2006, 07:09 PM
fastmatt98's Avatar
Well I think I'm going with the PRC's just for the price of course. Oh I had a LPE GT2-3 cam in that sounded stock I mean really it was incredible how stock sounding it was lol . Gave me a great pull up to 6300 rpm.
Old 02-26-2006, 07:13 PM
Restricted User
CAT3's Avatar
What about the Dart heads? Thought I'd throw that out before anyone else If it were for mild performance with "customer friendly" in mind, I'd go PP personally. Good quality low cost heads.
Old 02-26-2006, 07:28 PM
proautoman's Avatar
Why LS6 cam?
E
Myron @TPIS (owner) has just released a cam for the very reason you state He owns a CTSV and say the cam idles like sstock but
is worth 38 Ft lbs 952 448 6021 give em a call
Old 02-26-2006, 07:33 PM
Beast96Z's Avatar
You need to look into the port volume of the PRC's. There probablly a fair amount larger than the AFR's.
Old 02-26-2006, 08:19 PM
JZ'sTA's Avatar
I think if your staying with the Z06 cam you have tons of head options.
AFR's, TEA 5.3's, PRC's, etc. With your cam there isn't going to be a huge difference from head to head. Be happy if you pick up 20 RWHP over the stock LS6 heads with this cam.
BTW check out the cheeter cam from thunder racing.
I personially believe there are a ton of cam options that would be better then the Z06 cam. A 220/224 on XER ramp rates and a 117 LSA would be awsome for a stealthy combo and more power then the LS6 cam.
I know because I have used it before.
Old 02-26-2006, 08:59 PM
I am just looking for 20 rwhp, so that would work.
I've thought about the CheaTR, but want to try heads only due to the easier install. I did the HC on my GTO myself, but getting the A/C out of the way looks trickier on the V.
Thanks for all the replys...
I will check out the Darts.
Old 02-26-2006, 09:29 PM
Rescue Ranger's Avatar
i just bought some patriot stage 2 59cc heads w/ a cartek cam. I'll post up some results soon for ya, but i picked them on what you got for the price.. i don't really have a review yet tho
Old 02-26-2006, 09:38 PM
LS1 Tech Administrator
Patrick G's Avatar
The airspeed is so much higher on AFR 205s, you get the hp advantages, plus better fuel economy and throttle response. Think about it, no other head on the market gives you such high hp gains plus all the driveability benefits.
FWIW, my AFR 225s flowed about 20 cfm better than the 205s at .600 lift, but they only gained me 5 rwhp and 5 rwtq. In the process, I loss low speed driveability and about 2 mpgs on the highway. Keep this in mind when you're shopping flow numbers only. The 205s are the ****, flow numbers or not. The hp has to be feeled to be believed.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 02-26-2006, 09:48 PM
JZ'sTA's Avatar
No other head can give this? Why can elderbrock, Dart, ETP, Trick Flow?
EB, and Dart are also 205's and the ETP and Trick flows are 215's but have a better valve angle. 11* and 13.5* vs 15*.
I am just being a smart *** more or less.
I agree with what your saying just dont think a 2000+ dollar set of AFR's or ETP's are really worth it with a Z06 cam. Now if you plan on geting a better cam later then buying the better heads now is smart.
Old 02-26-2006, 10:55 PM
Exactly...
I don't plan to add a cam...so are the PRCs = to the AFRs (high priced heads) with the LS6 cam ?
If we are talking about the AFRs offering better "feel," I would assume this sensation would be translated into more TQ at lower RPMs ?
Old 02-27-2006, 07:35 AM
JZ'sTA's Avatar
Exactly...
The AFR's will still be better. They will make more HP and torque through the RPM band. The car will be a bit faster. Worth a extra 1200 bucks. On this one not to me, and trust me I have no problem spending money on heads.
For the extra 1200 bucks you could buy a cam, and pay for the install. I bet a better stealthy cam and the PRC LS6ers will wipe the Z06 can and AFR's.
Old 02-27-2006, 09:28 AM
That affirms it...
Throw the PRCs on it, then if I want to upgrade the cam - I can later. The only downside will be swapping the springs in the car.
Old 02-27-2006, 11:33 PM
uberLS-1's Avatar
how does that AFFIRM it...
JZ'sTA is right, a head only using AFR's will probably lose to a head and cam PRC...and honestly brand doesn't really matter. But we are only talking dragstrip performance here, not the day to day grind.
We all know the CTS-V is a little boaty...personally, I would opt for more low-end torque and throttle response, and what was said is the AFR's tend to be the best in that category while providing a substantial performance increase.
I doubt you are strapped for cash (Note your sig), so why not go for it. A little extra money, a few more smiles, not too mention the reliability of a better casting....
Ok, my opinion was voiced now I feel better.
Old 02-28-2006, 12:15 AM
Flow Wizard
Tony Mamo @ AFR's Avatar
Couldn't agree more....The 205's are tailer made for this application. I assume if you were focusing on the strip side of a street/strip dual purpose vehicle you would have opted for a lighter F or Y-Body....NOT the Caddy. The AFR 205's are ideal for a dual purpose street/strip car, especially ones wanting to place the emphasis on street (and hold their own quite well against much larger heads in strip applications as well).
Let's face it....this application is perfect for all the attributes the AFR 205's can offer you. A high flowing efficient cylinder head with a small cross sectional area will provide better low and midrange TQ (much needed in this application), increased snap and throttle response, better fuel economy, and will still make excellent peak power. High airspeed ports will provide better acceleration in the real world of day to day driving and the dragstrip.
The only reason not to get the AFR's are cost (if you feel the benefits they offer aren't worth the added expense), but the benefits they offer you are very real and if your budget allowed, their purchase will put a smile on your face every day you have the opportunity to drive it.
Don't skimp on heads....its the most important decision you will make when it comes to your combination and ultimately the end results on the chassis dyno, street, and track.
Feel free to contact me at AFR if you have any questions or concerns
Regards,
Tony M.
(818)890-0616 Ext 109
Old 02-28-2006, 12:20 PM
Ed Curtis's Avatar
He he he.. Yeah... my two ton goat runs pretty well with those puny 205 heads, stock short block and 3.46 gears...
Ed
Old 02-28-2006, 03:06 PM
gollum's Avatar
Patrick G pretty much summed it up. Thanks
P.S. Tony warned us long ago about this.
Old 02-28-2006, 07:39 PM
greenwood's Avatar
not to say anything bad tony why do the afr 205 need say 32-33* total
and a pos 5.7 may only take 28 -29 to make the same power
Old 02-28-2006, 08:53 PM
uberLS-1's Avatar
Not to speak for tony, but maybe less air/fuel for the timing to lead into? Just a thought...
assuming that was the only variable with the compression and quench remaining the same...
Old 02-28-2006, 09:56 PM
Ksett's Avatar
The AFR's are your best choice if you can afford them. They have a smaller 205cc intake runner with good flow at .500 which means higher velocity and more power. I would think the intake runner on the cnc'd head would be at least 230cc making much less velocity at .500 which equates to less power.
I'd find out what the intake runner is on the cnc'd LS6 heads.
