Opinions on my H/C set-up
After months of research and indecisions, I think I finally have my mind made up. But first of all, here are the goals that I had set for my car:
Primarily street driven with good street manners. Fun to drive around town.
The cam is a TR220 on a 114 LSA. The cam has been in the car for almost two years. The heads are to be AFR 205s milled to 64cc using Cometic gaskets with compressed thickness of .045". Static compression ratio should be around 10.5/10.6 to 1. And of course I'll have the supporting bolt-ons (LS6 intake, headers, etc.)
I went with this cam to pass CA smog (a bigger cam would have been nice ) and only a little bump in compression due to 91 octane. On top of all this, I plan to throw a 100 shot (dry) a little later down the road.
My only concerns are this:
1. I'm guessing my quench will be somewhere between .035 and .040. Will this be OK?
2. Will it be safe to spray with this set-up on 91 octane?
Please offer your opinions/suggestions.
Thanks,
Brian
Thanks,
Brian
Thanks,
Brian
Thanks,
Brian
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Most definitely.
I think for smog you can get all the way up near 230 on the duration. A TR224 would be a good choice too if you could get a 114 cut.
Also:
If you are going to spray a H/C, also remember that you are gonna want to get some good injectors so you don't end up with a nice cup of LS1 Soup.
Also:
....The heads are to be AFR 205s milled to 64cc using Cometic gaskets with compressed thickness of .045". Static compression ratio should be around 10.5/10.6 to 1. ...
Your DCR will be what determines if you can run on 91 Octane. What is the advance (ICL) of that cam?
+2 advance (112ICL) DCR is 8.54....Border-Line on that gas ( you will have to pull some timing)
+4 advance (110ICL) DCR is 8.68....No go on that gas
AGAIN, I got these number using .006 piston height, which seems the be average. Mine were .007-.008
Originally Posted by SideStep
10.5 How far are your pistons out of the hole??? Even if the pistons were perfectly flush with the deck (and they are not) I get 10.73ish for the static. If you were only .006 out of the hole I get 10.88 for the static...
You're right. I re-checked the numbers and with that gasket thickness my compression would be hovering around 10.8. Probably should go with a thicker gasket like a GM 6.0L (.055" ?)
With regards to the ICL, yes it is a +4 advance. How did you calculate DCR? Looks like I'll need to know this since this appears to be my limiting factor.
Brian
SideStep,
Brian
Brian
I will find the link to the spreadsheet I am using....
