Cam help!!!!!!!!! Please
was planning on using this
FMS Custom Grind Camshaft - 228"/230" .576"/.595" 112LSA - aggressive profile with a 2200-6600 RPM range, fair idle
BUT....... I ordered it from Futral on 3 FEB and it is still not in yet and they are not sure when it will get in so I may cnacel my order. I will be installing Mar 11-12 and if I I don't have a cam then there will be no install. HELP what are some similar grinds. I want a drivable cam to work with my 3.42's but 400+ RWHP. NEED HELP. Thanks Scrappy
M-6 SLP longtubes Ls6 Intake and LOUDMOUTH
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well, I DD my 244/248 cam.
Anyway, you could probably use the money that you were going to get that cam with and just go with a used grind from the for sale section and have it in a matter of days. If you have a good tune any cam will work just fine. What is your ultimate goal for the car though?
