switched to synthetic oil, now getting knock codes
Old 02-28-2006, 06:18 AM
circusboy's Avatar
Default switched to synthetic oil, now getting knock codes
I was using regular oil for about 12k miles. i decided to start using mobil 1 synthetic oil and now my car keeps get getting a knock sensor code. It comes on for a couple of days then goes away dor a couple of days.
I can actually here the engine knock. Has this happened to anyone else?
Will this hurt my motor?
please help. It's driving me crazy.
p.s. my gas milegage has gone down @ 5 mpg.
Old 02-28-2006, 06:23 AM
2nd fastest 5.3 ECSB
trever1t's Avatar
Did you change viscosity? I cant imagine any issue caused by M1, i've been running it for years and found the opposite of what you describe. Sounds like a coincidence that your getting codes.
Old 02-28-2006, 06:40 AM
Race your car!
JL ws-6's Avatar
I dont' think that the oil cuased teh problem.. unless you forgot to fill it. J/K, I'd find someone with an autotap, see what's going on, I've never heard of anyone switching to aynthetic and having that happen... whatever went wrong, just happen to go wrong at that time.
Old 02-28-2006, 06:57 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Talk to Patman....
Old 02-28-2006, 10:39 AM
circusboy's Avatar
thanks for the replys.
i haven't tuned it since i put on the headers, ORY. i think it's running rich. maybe that's causing some problems. i will be getting it tuned soon. i'll have them look into it
Old 02-28-2006, 09:14 PM
circusboy's Avatar
i noticed the sticker the oil change place put on my window.
it says they used 15W-30. could that be the cause of my problem?
is this oil to heavy?
Old 03-01-2006, 05:09 AM
Race your car!
JL ws-6's Avatar
15-30? Who makes a 15-30 wt oil ?
Old 03-01-2006, 06:34 AM
blackbirdls1's Avatar
this same thing is happening to me, I just bought my car and after I changed the oil to Mobil 1 synthetic, I am now getting a knock / ticking noise, I have heard that this is common on LS1's but I am not sure. I am going to change the oil again to clean it out from what was previously used. Another thing the only difference between you and me is that I'm not getting any knock codes.
Old 03-01-2006, 06:47 AM
circusboy's Avatar
i think i will check the pcv system. i had a hole in one of the hoses when i purchased the car that gave off some strange area codes.
Old 03-01-2006, 11:30 AM
dailydriver's Avatar
As far as I know, it does not exist!
Old 03-01-2006, 11:34 AM
circusboy's Avatar
Must Have Made A Mistake When They Typed The Label.
I'm Starting To Think This A Fuel Problem. A Co-worker Was Behind Me Yesterday On The Way Home. He Said When I Got Down On It A Lot Of Black Smoke Came Out The Pipes.
Old 03-05-2006, 05:21 PM
circusboy's Avatar
Default got it fixed.
i changed the spark plugs yesterday. i put in some ngk t55-v power.
the check engine light has not been back on and the gas mileage has come back.
i guess what i'm hearing on cold start ups is piston slap.
thanks for all the help
Old 03-05-2006, 06:26 PM
1hardmaro2's Avatar
Had the same issue but somehow I had about a quart and a half to much oil; not paying attention I guess. Check your oil level..
