What is a safe rev limit (come inside for more info)
Old 03-01-2006, 03:22 PM
FSUNole17's Avatar
Default What is a safe rev limit (come inside for more info)
I am putting in a small blower cam on 918 springs with chromemoly hardened pushrods soon and eventually will be getting blown (i love saying that) anyways, all the other internals are stock, what is a safe rev limit that i should run? thanks!
Old 03-01-2006, 04:27 PM
Happy Jim's Avatar
Hmmm, don't know but am interested also.
I'd guess you would be limited by your stock con rod bolts as well.
ttt
Jim
Old 03-01-2006, 09:07 PM
zspot98's Avatar
With swapping rod bolts I've seen people safely run between 6800 and 7200. Mine is set @ 7100 with my WOT shifts @ 6900. But I guess every engine is different? Just my .02
Old 03-01-2006, 09:15 PM
camaro608's Avatar
i wouldnt take it to much over the stock setting just to be safe.
Old 03-02-2006, 01:15 AM
Michael55123's Avatar
Dunno, I have mine set to 6700, but that's with some ARP rod bolts. I could just be a big ***** too.
Old 03-02-2006, 01:23 AM
PREDATOR-Z's Avatar
Originally Posted by zspot98
Without swapping rod bolts I've seen people safely run between 6800 and 7200. Mine is set @ 7100 with my WOT shifts @ 6900. But I guess every engine is different? Just my .02
You really don't actually believe that? Do you?
6300 is a "SAFE" area and above that probability of failure increases.
MOTRUBL's Avatar
I took mine to 6800. This was with a stock motor with only a 230/230 cam and 918 springs. I'd even launch off the limiter sometimes. No problems here.
Old 03-02-2006, 01:25 AM
TopFlite's Avatar
Car's rev limiter is set at 6800 and shifts at 6500 with stock rod bolts.
Old 03-02-2006, 01:32 AM
StangEaterSS's Avatar
i shift around 7k rpm. stock rod bolts prolly not safe. but it makes power up to 7k.
AnoxieGTO's Avatar
yeah aren't LS6 Rev limiters like 6500 or somthing..? thats what I have mine set to...I have double springs and harden push rods tho....
Old 03-02-2006, 01:50 AM
FstBlkz28's Avatar
My limiter is set at 6800, and my shift light is set to light up at 6400 so that i'm shifting around 6500-6600.
My cam pulls all the way to 6800, but I don't see the point in running the car that high when I'm racing b/c of the added risk of failure.
Old 03-02-2006, 06:45 AM
zspot98's Avatar
Well I guess I need to kick my tuner in the nuts for setting up me up for failure?
Old 03-02-2006, 07:07 AM
JRracing's Avatar
I was shifting at 6400 last year and this year I think I will twist it a little bit hard. Maybe as high as 6700.
Old 03-02-2006, 07:24 AM
MSGHUFF's Avatar
I have mine set @ 6700 and bounce off it a lot and feel pretty safe about it. Anything higher I would start to worry. I have friends with stock bottom ends set @ 7050 shifting @6900 seems a little high to me but everyone has a different opinion on this...... Without any facts to support it, I personally feel 6600-6700 is the max safe limit...
Old 03-02-2006, 08:07 AM
Steel Chicken's Avatar
stock valvetrain starts floating around 6500
rods will let go a little after that
but with upgraded valvetrain and rods bolts, people do 7K all the time
Old 03-02-2006, 08:20 AM
777's Avatar
What kind of cam do you have. Stock cam doesn't make power that high. Neither do 80% of the off the shelf cams.
Old 03-02-2006, 10:59 AM
FSUNole17's Avatar
for reference, the stock limiter is 5800, correct?
Old 03-02-2006, 11:01 AM
PREDATOR-Z's Avatar
On LS1 f-bods correct
Old 03-02-2006, 11:03 AM
FSUNole17's Avatar
wow that seems kind of low, but here is another question, is it pointless to move the limiter up if u are making all of your power below that? say u peak out and start droppin HP around 5500, does raising the limiter do ANYTHING for u?
Old 03-02-2006, 11:20 AM
zspot98's Avatar
No, but most cams I've researched make power to at least 6600 rpm's.
