10* beadlock valve locks?
Old 03-02-2006, 12:04 AM
Greg Fell's Avatar
Default 10* beadlock valve locks?
Has anyone used a 10* bead lock before, and if so where did you find them? I see comp cams is coming out with one, but summit told me it would be a month before they were available.
I need a retainer to fit my K-Motion K800 springs, and all the retainers that will work are 10*.
Old 03-02-2006, 12:57 AM
Collections Hold
Cary@Perf-Induction's Avatar
Default bead locks
Greg,
We have been using the Manley .311 bead locks, It will fit a .3135 pretty tight though. We centerless grind the tips of our valves to .311 so the variety is there. B&B will have some too, but around the same time as COMP.
You are kinda stuck. titanium is hard to grind, but a good grind shop can do it.
Comp has a 7degree retainer to fit the 987 spring I believe which was made to fit the stock keepers, you may want to look into that.
Cary
Old 03-07-2006, 09:06 AM
Greg Fell's Avatar
I found the comp 10* 8mm (LS1) beadlocks, direct from comp.
Old 03-07-2006, 09:09 AM
Cstraub's Avatar
B&B our 10 degree is 8 weeks out.
Quick Reply: 10* beadlock valve locks?
