radiator....HELP!!!!!!!!
Old 03-03-2006, 12:49 PM
EVIL TA's Avatar
Default radiator....HELP!!!!!!!!
i just parked my car and it sounds likes something is boiling? its coming from the radiator cap. i change my radiator fluid and filled it up, (not to long ago) i dont have any leaks anywhere. my light does come on but i think my sensor went out??? i think? why would my radiator fluid be boiling? bad radiator? water pump?
Old 03-03-2006, 02:43 PM
ILLWS6's Avatar
You may be overheating. Make sure your fan is coming on when the car warms up. If the fan works, Try a new radiator cap. If the cap is good check the thermostat. If that checks out I'd have the cooling system pressure tested to check for a head gasket leak.
Old 03-03-2006, 08:03 PM
Grimes's Avatar
Ill is right - the stock radiator caps fail all the time. Replace that and it will likey solve your problem.
