cam or convertor?..that is the question
mods are slp lid,pacesetter lt's,tsp ory,and hooker catback.which one should i do first.convertor and super cooler,or TR224/224 114 lsa.i am doing both but only have the cash for 1.....HELP
converter will give you a better result than a cam. Cam w/out a converter would kinda suck, imo the stock converter is too small for the stock cam as it is.
If you plan on getting a cam in the future, be sure to match the converter and cam.
Originally Posted by fastSS2002
thanks for the replys guys,looks like the convertor will be done first.anyone have any advice on what convertor to go along with a TR224/224 114lsa?
Differential gear ratio
Cam shift points
and what you intend the car for (Street, Street/strip or Strip only)
Judging by your choice of cams I would say occasional strip so:
(2.4/2.5 str)
VIG 3200
YPT 3500
TCI 3500
Fuddle 3400
(for diff gears of 3.42 up)
If gears less than 3.42, then a tighter str would benefit more.
