how to tell if there is a spun bearing
Old 03-06-2006, 01:12 PM
92zcamaroperson's Avatar
Default how to tell if there is a spun bearing
How can I see if there is a spun bearing? The block is not in a car and the heads are off. If I turn it will I hear anything? And if I start taking the pistons out and take the crank out can I reuse all of the bearings and parts as long as I keep everything in order? I bought this short block and he says it has a spun bearing but really has no idea where so I want to look around.
Another question is if I want to have the block hot tanked do I need to remove the crank and pistons? and everything?
Any suggestions would be greatly appreciated. Thanks.
Old 03-06-2006, 01:51 PM
Fireball's Avatar
pull the rod caps off, a spun bearing will be pretty obvious when you look at them.
Don't reuse any of the bearings upon reassembly.
Old 03-06-2006, 01:52 PM
2002yroneformula's Avatar
Might be mistaken, but you're gonna need to definately look at the bottom end. For the cost of it...I'd just go ahead and buy new bearings depending on how much wear is on the old ones. I mean why not since you're already gonna be in there.
As for hot tanking, everything needs to come out....pistons, rods, crank, bearings....everything.
Old 03-06-2006, 01:56 PM
gollum's Avatar
Do not use the rod either. Try to rebuild or replace all rods for good insurance.
Old 03-06-2006, 02:28 PM
the connecting rods themselves? Why do I have to replace those? I know there are some performance gains but since im not going for anything major powered wont they work just fine?
Old 03-06-2006, 02:38 PM
assuming the bearings are all fine *crosses fingers and prays to God* what size bearings do I need? Jegs doesnt really specify "ls1 rod bearings". And do the bearings just set right in or do they need to be pressed in? I guess I might as well change all of the bearings and do the cam bearings as well.
Old 03-06-2006, 02:40 PM
MrDude_1's Avatar
if you're not doing high RPM (higher then stock), and you're not running a major power adder, then yes, they will work just fine.
however, if theres any doubt that the rod bearings could have spun, have the crank and rods checked by a shop.
if they find something bad, they saved yuo money in the long run.
if they say everything is good, you can slap it back together with new bearings and be assured its correct.....
having it checked is not very expensive, and if the motor is out, and there is any doubt, its money well spent IMO.
dont be afraid of the bottom end, theres no magic in the bolts. they're just bolts, like the topend of the motor...
Old 03-06-2006, 02:43 PM
Not sure on the size, but the bearings will just kinda "snap" in the rod caps, main caps, and block. Just make sure they're clean and dry when you install them, than put plenty of assembly lube on the bearings. Cam bearings shouldn't need to be changed unless you're gonna be changing the cam if the cam journals aren't abnormally worn.
Definately have the rods and crank checked if there seems to be a spun bearing though.
Old 03-06-2006, 02:53 PM
im deffinetly changing the cam. Should I take the whole block in or can I just take the crank and rods in for inspection? I was wanting to spin to about 6200 and set the limiter at 6500. Id be putting arp rod bolts in and main bolts. BTW I cant seem to find main bolts on jegs just main studs.
Old 03-06-2006, 02:55 PM
gollum's Avatar
All spun bearing incidents (knock,knock,knock) I have witnessed, the crank had to be turned.
Old 03-06-2006, 03:15 PM
crank had to be turned but did the block have to be line bored? Or were oversized bearings installed? And where could I find out what bearings I need?
Old 03-06-2006, 03:57 PM
s346k's Avatar
it sounds to me like you need to consider taking your entire shortblock to someone and let them work with it.
just judging by your questions, i gather you don't know a lot about engines, which could lead to problems in the long run if you try to tackle this yourself.
Old 03-06-2006, 04:15 PM
gollum's Avatar
Yea, I learned the hard way about importance of rod big end measurements and proper bearing crush. It was spin city until then
Old 03-06-2006, 05:03 PM
s346k's Avatar
yeah, we've all made dumb mistakes rebuilding a motor at one point or another. i've just caught mine before they ended up costing me more $$$$.
this is just a bad motor to mess up on, it ain't like rebuilding a gen 1 sbc. this dog is much more money hungry.
Old 03-06-2006, 07:07 PM
Yup, starting to think the same myself. Take the whole thing to a machine shop that you trust and have them check everything. Than you'll know where to go from there.
Old 03-06-2006, 07:11 PM
freakynipples69's Avatar
This is what a spun bearing looks like.
Old 03-06-2006, 07:14 PM
chipz's Avatar
holy sh$t
Old 03-06-2006, 08:19 PM
lol yeah.
Old 03-06-2006, 08:25 PM
haha thats funny. I spun the number 7 as well.
Old 03-06-2006, 08:26 PM
Kounsy's Avatar
ya my engine went the same way, mine spun number seven and u have to take the pan off and it really sux,
