What APR bolts do you suggest for the minimum?
Old 03-06-2006, 06:36 PM
freakynipples69's Avatar
Default What APR bolts do you suggest for the minimum?
For what I have below in sig(including the coming engine), what are the minimum APR brand bolts do you suggest I should get over stock bolts?
Old 03-06-2006, 09:50 PM
Nate_Taufer's Avatar
Plan on spraying?
Nate
Old 03-06-2006, 10:30 PM
SSU's Drunk Typing Whore
Lithium's Avatar
ARP main studs/ Head studs to be 100% safe. Otherwise you should be fine with stock bolts if you are running just a cam/ H/C setup. With FI its a good idea to go with studs.
Old 03-07-2006, 07:01 PM
67Ranger's Avatar
You should definetly also upgrade the rod bolts, dont know if those are already in the new engine or not. But Main studs, rod bolts, and head bolts/studs are about all you should need. Possibly their header studs, and flywheel bolts, but those arent really necessary.
Old 03-07-2006, 07:11 PM
Lithium's Avatar
Did the 00's get the stronger rod bolts?
