heads for a 6.0
Old 03-09-2006, 09:55 AM
chevydad's Avatar
Default heads for a 6.0
which of the stock heads would be the best choice on a budget 6.0 builup. i'm looking at dropping the motor into a fox body. adding the edelbrock carburated intake and a nice sized cam. would ls1 or 5.3 heads be a better choice over the stock 6.0 heads? what kind of power would this setup make with say a trex or magic stick sized cam.
Old 03-09-2006, 01:55 PM
chevydad's Avatar
surely someone would no which heads would work best.
Old 03-09-2006, 02:45 PM
ArcticZ28's Avatar
5.3, ls1, or ls6 heads are gonna shroud the 4.000 cylinder. I'm running the stock 317 heads from a lq9 6.0.
Old 03-10-2006, 08:04 AM
chevydad's Avatar
i haven't actually seen this motor yet, a buddy of mine has it, but it might be a 99 and have the iron heads.
Old 03-10-2006, 08:10 AM
Kraest's Avatar
LS2 heads or something else on a 4" bore.
Carbuerator?
Old 03-10-2006, 09:11 AM
Gunnar@Patriot's Avatar
We can sell you a set of assembled OEM 243 (LS2) heads non ported for $675 plus shipping. Or we can sell a set CNC ported assembled with OEM parts for $865 plus shipping.
Old 03-10-2006, 09:49 AM
black01_WS6's Avatar
gunner beat me to it. good bang for the buck there.
Old 03-10-2006, 10:15 AM
chevydad's Avatar
what is the difference between the cast iron headed 6.0 and the aluminum headed version? this is what i'm being told.
Originally Posted by whitt1
I would avoid the early model 6.0 with CI heads,it uses a different crankshaft flange that only works with a 4L80E transmission.Pass on the 99 model 6.0.
Old 03-10-2006, 10:35 AM
Zick's Avatar
Weight and I heard they don't flow as well.
Also, Whitt1 is correct. The iron headed version has a wider crank flange designed to be bolted up to the 4L80. It will not bolt directly up to a 4L60 if you plan on using that.
Old 03-10-2006, 10:44 AM
chevydad's Avatar
no, i plan on using a th350 and the hub spacer/adapter for the convertor.
