CAM XER 230/230/.592/112+2 and PRC LS6 heads
Comp Cam XER custom grind .230/.230/.592 with LSA 112 + 2 with TSP LS6 PRC Heads for 899 dollars? How will my idle? Will this Head/Cam combo work together? What type of power will I put down with my built 4L60E automatic + Fuddle 3800 stall setup? I have all the supporting mods.
Moderator
I am running a very similar combo. Great combo!
After a lot of idle tuning the car has no problem with start-ups or idling. I have never dynoed this combo but the car runs consistent low 7s in the 1/8 mile.
John
John
It will make great power! That is very similar to my setup save the auto trans. It layed down 432rwhp untuned with stock Ls6 intake. You must remember however you are not going to throw out big dyno numbers with an auto and stall. Id be happy with 400-410rwhp...
Also Id recommend upgrading to the PRC duals for an extra 200 bucks, my heads ran $1149 with the PRCs installed.
