Decided on cam...need a little help
Decided to go with a f11 cam for my heads I will be putting on (pp stg 2 ls6).
I will be getting it on a 112 lsa.
What advance should I have it ground with?
I want to be shifting at no later than 65-6600. Kind of worried about the stock 98 botttom end with 91k on her.
SO I would like the cam to peak out at around 6400....I thought that this cam was in that range and I could hit that mark with changing the advance a little.
thanks, Troy
thanks, Troy
Originally Posted by UltraZLS1
So am I correct in thinking that this cam doesnt require any revving past 6600.
The more advance the more it lowers the rpm range....and a 112 will lower it also...correct?
Anyone have any graphs?
