Quick cam question....
Old 03-10-2006, 02:48 PM
LS1TECH Sponsor
Azar's Avatar
Default Quick cam question....
I just got a used G1 cam from a member here, and I thought it was just the standard G1 cam.
But upon opening the box, at the end of the cam it says
MTI G-1 on 115 LSA and then under that it says +4....what does that mean?
Old 03-10-2006, 03:00 PM
shouldaboughttheZ's Avatar
+4, I believe is the degree added to the cam. Did you know this when you bought the cam?
Old 03-10-2006, 03:05 PM
LS1TECH Sponsor
Azar's Avatar
I just read the cam guide that's a sticky on this forum and it says that normally +2 or +4 advance is ground into most off the shelf cams, so maybe it's like this.
But usually the G1 is on a 113 LSA, not a 115 LSA. And I didn't know this when I bought it..
Old 03-10-2006, 03:38 PM
Maybe it was a special grind cam with the original owners specs.
Old 03-10-2006, 04:42 PM
LS1TECH Sponsor
Azar's Avatar
I don't know, I'm going to contact MTI and figure out what is going on. I'm sure it's a special grind of the G1.
Old 03-10-2006, 08:00 PM
SideStep's Avatar
The 115 is the LSA, +4 refers to the ICL being 111. The normal G1 cam a 113 LSA and an ICL of 109. I have a 115 LSA version sitting in my basement. It will have a very good idle but will give up low-end TQ compared to the 113 LSA version...
Old 03-11-2006, 01:43 AM
LS1TECH Sponsor
Azar's Avatar
So it will have strong low end torque, and the advanced timing will give me more power in the higher region of my powerband?
