!What do I torque my stock rockers to?!
Old 03-10-2006, 03:41 PM
BADSZ28's Avatar
Exclamation !What do I torque my stock rockers to?!
I need help quick. No internet at home and leaving work soon. What do I torque them too. When I pulled them off felt like over 22lbs like said in the LS1how to right up. Please help.
Old 03-10-2006, 03:42 PM
Ωmega's Avatar
they're 22lbs but put locktite on them.
Old 03-10-2006, 04:36 PM
Camaro99SS's Avatar
And make sure the threads are clean with no dirt that could give a false torque reading. Soak the bolts in gasoline if they're dirty. That'll clean them up really well.
Jason
Old 03-10-2006, 04:52 PM
BigBlockChev572's Avatar
I've found Electric cleaner works great too. Cleans and dries the bolt instantly.
Old 03-10-2006, 05:07 PM
dyls1's Avatar
I never heard of putting loctite on them, I was always told to keep loctite out of the internals of an engine. And if you are supposed to use loctite what color/strength should be used?
Old 03-10-2006, 05:38 PM
That is all I have to say.
Old 03-10-2006, 06:20 PM
Viper's Avatar
You can put loctite under the washer part. Under the washer doesn't get to the internals. For the bolt threads themselves, people have used teflon paste. Especially if you have ported heads; a good chance the rocker bolt will poke through to the ported intake side ( exhaust doesn't poke thru ).
Old 03-10-2006, 06:22 PM
Moderator
davered00ss's Avatar
22 ftlbs. be carefull, they break easy.
Old 03-10-2006, 11:26 PM
Ωmega's Avatar
That's what I meant, I should have been more clear
