LS1/LS6 Oil pump?
LS1/LS6 Oil pump?
My car is A 2001 SS
is ther a such thing as a LS6 oil pump, i heard that all 2001 and up LS1/Ls6 oild pumps are the same???
also what is done , when other co, port and shim it?
is this something i can do to my stock 01 oil pump,
and one have a link or pictures to a DIY guide.
All I know is the 01+ have the better oil pumps, I think your oil pump is the same as an ls6 design. Ls1howto.com shows how to install but not positive of it shows how to port.
Originally Posted by Lawnboy
My car is A 2001 SS
SLP sells the shim and it installs by removing an 8mm allen plug on the side of the pump. Add thread locker and reassemble.
If you decide to do it yourself and need torque specs, let me know.
I've dis-assembled and measured pre and post 2001 pumps (LS1 / LS6), and they were identical. Even had the same casting numbers on the case. IMO no such thing as an "LS6" pump. If you ever had one apart you'd agree.
Originally Posted by SMonty
I'm also interested in how much porting is needed. Has anyone made a DIY guide?
It will be obvious to you when you look at the oil pump where to remove some material. I'll see if I can find the pics. PM me your email address.
Later
