Coil Packs.. Which one is Which?
Old 03-10-2006, 04:57 PM
H8 LUZN's Avatar
Default Coil Packs.. Which one is Which?
Well in the fall when i took the coil packs off, i forgot to label which side is for which, How do i tell the difference??? (i bagged and tagged everything else.. hmm)
I was looking for somthing obvious.. but didnt really see anything.
Hopefully it'll be running again this weekend..
Old 03-10-2006, 06:03 PM
joshp14's Avatar
The coils themselves dont matter...the brackets i think only fit on one side. Try one side, if it doesnt fit, it goes on the other side.
Old 03-10-2006, 06:46 PM
H8 LUZN's Avatar
oh, ok.. that will make life easy.. thanks.
Old 03-10-2006, 07:04 PM
JRracing's Avatar
No I think each coil goe to a certain cyl. Not totally sure but I seen someone else talking about that.
Old 03-10-2006, 07:23 PM
H8 LUZN's Avatar
The only thing that makes a difference is how the connector and wires are routed in the coil pack bracket. If one side is wired differently then there will be problems if it is placed on the opposite side, which i think is the case. If they were smart, they would have made the coil pack bolt patterns non interchangeable.. (hopefully)
Old 03-10-2006, 07:25 PM
jermzz's Avatar
If you put them in and it doesnt start, you might have to switch them 180 out
Old 03-11-2006, 01:00 AM
MEFISTUFF's Avatar
Default coil pack id
look @ the coil pack connector, the solid color wires are odd, wires W/
tracer are even side
Old 03-11-2006, 05:48 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
They only mount one way.
