head gasket showdown
Old 03-12-2006, 12:45 PM
RUTAN TA's Avatar
Default head gasket showdown
What is the best headgasket for a nitrous motor? alot of nitrous!!!!
I was going to run a GM MLS gasket off a 05 LS1,but my machinist wants me to run a set of copper scce(?) gaskets.
Old 03-12-2006, 01:15 PM
kenp's Avatar
Those copper gaskets are good. Your bigger issue may be head bolts. With the nitrous you probably should install aftermarket head bolts or studs like ARP.
Old 03-12-2006, 01:21 PM
cantdrv65's Avatar
Post
Id probably follow your machinists advice but I would definitely go with the ARP headstuds....
Old 03-12-2006, 05:30 PM
Nate_Taufer's Avatar
Either the Titan sce gaskets, or cometic head gaskets. You need a smaller quench with nitrous motors so I would suggest a .040" compressed thickness gasket.
Nate
Old 04-11-2006, 06:05 PM
_HAVOC_'s Avatar
this threads about a month old, so im bringing it back up because I'm also tring to decide on which head gaskets to go with, its for a forged 382 ci thats gonna see a lot of nitous.
I've seen a couple of other threads talking about the titan gaskets, but it seems like not to many people have used them yet. so i don't know if it can even justify the extra $ or hell, even if they are the same price are they even better than GM MLS?
Thanks in advance for any input.
Old 04-12-2006, 01:03 AM
strokedls1's Avatar
My buddy did gm mls on a 382ci with a 300 shot. I'll let you know how it holds up. It worked fine with the 200 shot for a season with those gaskets. We used some copper spray on the current ones to help with any sealing issues.
Old 04-12-2006, 04:23 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
ARP studs did it for me.
Old 04-15-2006, 10:28 AM
bad95killer's Avatar
Me & My buddy really concern about head gasket & bolts for his torquey SS so i'd like to hear more info then we could decide
peace
Old 06-09-2006, 03:20 AM
mr2guru's Avatar
SCE Titan ICS, no doubt.
Old 06-09-2006, 04:50 PM
Beast96Z's Avatar
Agree'd. I had bad luck with Cometics on my last motor, so I'm gunna use the Titans this time.
Old 11-13-2006, 02:59 AM
Restricted User
1fstGM's Avatar
Same here. I have gone through 2 sets of cometics. This time around I am gonna try the SCE Titan. I'll keep you guys updated on the results.
Old 01-02-2007, 10:49 PM
The Sad's Avatar
Any word on the SCE Titan?
Old 01-03-2007, 07:51 AM
DAVESS02's Avatar
Im using them with the integral o-rings and ARP studs. No problems although I'm not running any nitrous yet. I did re-torque twice FWIW. Those gaskets cost $189 through JEGs.
Old 01-07-2007, 06:06 PM
Restricted User
1fstGM's Avatar
SCE Titan will not blow. I blew a forged piston before the gasket.
Old 01-07-2007, 06:29 PM
GuitsBoy's Avatar
Do you need to groove and o-ring your motor for the SCE titans though? I remeber there being a good reason why people didnt want to run them on the street.
Old 01-12-2007, 11:22 PM
mr2guru's Avatar
Not for the ICS version. Although I am pretty sure their regular titans, you do as they are just copper gaskets like any other.
Old 01-12-2007, 11:37 PM
DAVESS02's Avatar
Since the o-rings are internal to the gasket, there's no need for o-ring groves in the block. The edge of the combustion area of the gasket is split and the steel ring is inserted and then it looks to me that the gasket is ran through a roller to bring it to the desired thickness over the ringed area.
Old 01-13-2007, 04:24 AM
koolrayz's Avatar
felpro has a new 4 layer MLS gasket out that has been tested in some high (2000) hp applications, There in the procees of doing some ls1 testing they have an adhesive already on them to help sealing. I have had good luck with the cometics, I also have a set of the titans at home but I may try these felpro even tho the felpro blue 1041's are
