Spun bearing....
Old 03-12-2006, 06:46 PM
6spdpewterZ's Avatar
Default Spun bearing....
I guess I really did it this time. What em I looking at money wise?!
Old 03-12-2006, 08:06 PM
wrencher
wrencher's Avatar
A rebuild or a used short block basically.
Old 03-12-2006, 08:11 PM
cantdrv65's Avatar
Post
Yep the crank and at least one rod will have to come out. What was the oil level like when this occurred? also how high do you spin the motor?
Old 03-12-2006, 08:13 PM
9 Second Club/Nitrous Mod
shortdog's Avatar
Stupid question, but what are the effects (engine behavior) of a spun bearing and what usually causes it?
Old 03-12-2006, 08:21 PM
cantdrv65's Avatar
Post
High RPMs causing rod bolt stretch especially on the pre-01 Ls1. Another possible cause: an ls1 run about 1 to 2 quarts low on oil will also loose oil pressure sometimes at high rpms.
Old 03-12-2006, 08:37 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Think of it as an excuse for a 383.
Old 03-12-2006, 09:34 PM
The level was normal. Nothing out of the ordinary. 80+ psi?
dont have the money for that just yet
Old 03-12-2006, 09:37 PM
A lot of kncking
Old 03-12-2006, 09:41 PM
cantdrv65's Avatar
Post
So the engine was full of oil, I mean via the dipstick? Also how high do you rev the motor? 6800? 7k?
If full of oil you probably streched a rod bolt at high rpm.
Old 03-12-2006, 09:43 PM
I messed up there.....67..
Old 03-13-2006, 07:56 AM
GuitsBoy's Avatar
6700 dosnt seem all that far a stretch even for an 00 with the weaker rod bolts. Did you beat the car like a rented mule every time you took it out?
Old 03-13-2006, 09:27 AM
that is funny. No I just never took it at high speeds ever 130+. I only ran it at the track a couple of times but I guess I over did it this time.
Old 03-13-2006, 09:57 AM
777's Avatar
Are you positive you spun a bearing. What's your symptoms?
Old 03-13-2006, 10:04 AM
Fireball's Avatar
I've seen strong detonation do it too
Old 03-13-2006, 11:30 AM
Loud knocking and extremely low pressure. I am guessing I spun a bearing since I am a newbie to this. What else could it be 777?
Old 03-13-2006, 11:38 AM
cantdrv65's Avatar
Post
Sorry man it sounds to me like your diagnosis is correct. I agree that 6700 is not too high, I spun my 99 that high and got 114,000 miles out of the thing. Detonation as Fireball mentioned may have caused it, or maybe the engine was slightly loose from the general.
Old 03-13-2006, 12:37 PM
Thanks for your input guys. The LS1 will be coming out this weekend. I will post pics as we dig into the ls1.
Quick Reply: Spun bearing....
