will the G5X-4 cam clear pistons in stock LS1 short block?
will this cam clear the pistons or i will have piston to vlave clearance problem?
i'm not sure but i might use ported stock heads with stock valves or AFR 205 heads with 2.055"/1.60" valves.
so will this cam with above heads ( with the valve sizes indicated) clear the factory pistons?
both heads will not be milled.
so the compression might still be at 10:1.
i'm thinking of using these combination with QTP race headers and FAST 90/90 until the new L-92 block apears.
thanks for help.
thanks for help.
