Ms3????
Old 03-13-2006, 04:04 PM
Z28LS1camaroguy's Avatar
Default Ms3????
Ive been hearing alot of good things about the MS3 cam that TSP sells and am wondering what are the specs on it??? and how much HP does that cam alone with a full exhaust produce??? anyone recommend a different cam thats better than the MS3, im looking for a loud lopey cam that gives alot of HP and sounds bad ***.
Old 03-13-2006, 04:38 PM
nokeman's Avatar
Well the MS3 would pretty much be that cam. There is always the TREX but that is a little more radical and would need ALOT of tuning. There are other cams out there though that compare to the MS3...F15, G5X4, and some others. Just use the search button and you will get loads of results on that and all the other cams. Biggest thing though is to do ALOT of research before deciding which cam is best for you, i.e. drivability, power curve, etc. But the MS3 is a great cam, one that many have chosen and I will be installing in a couple months.
Old 03-13-2006, 04:54 PM
walker94z28's Avatar
I have it and have found no flaw other than having to go to a bigger converter. It took my N/A times on and 1/8 mile track from 7.50 with a 1.60 60", best with stock cam to 7.18 @ 95.72 mph with a 1.58 60" with the MS3. I dont have any dyno numbers yet but I hope that helps. All my mods are in sig.
Old 03-13-2006, 05:16 PM
Zach@Texas-Speed's Avatar
The MS3 is for you!! This cam has consistantly made great numbers, plenty of people daily drive this cam. If you have any questions about anything pm me on here or give me a call!
-Zach
Old 03-13-2006, 05:29 PM
FUN LS1's Avatar
...what nokeman said, plus you might look at this cam, too:
http://www.texas-speed.com/shop/item...d=169&catid=44
Old 03-13-2006, 08:46 PM
JDM_99Z's Avatar
I daily drive this cam and its wonderful. I love it! The specs are 237/242 .603/.609 113. It behaves pretty well after a good tune.
Old 03-13-2006, 09:15 PM
Louie83's Avatar
What if you have a manual and are on the highway a lot?
You would need to go 4.10's and it seems like it would totally botch your gas mileage and driving around town sounds like it could be a chore?
Old 03-13-2006, 09:21 PM
obrien24's Avatar
I have 4.10s and a 12 bolt in my car. The car put down 413/380 with pretty much full bolt ons and through slp long tubes with true duals. As far as driving around town, I can run 40 mph in 6th gear at about 1k rpms.
Old 03-13-2006, 09:51 PM
nokeman's Avatar
Gas mileage will not be greatly affected. You can put the car in 6th whenever you want. The only that will hurt you MPG will be your right foot constantly on the gas because ur car is gonna pull like a sumbitch and sound incredible!
Old 03-13-2006, 09:57 PM
i have an automatic and plan on getting the 3.73s here first along with a fuddle racing 3600 stall.
Old 03-14-2006, 10:11 AM
vodas00ss's Avatar
Im driving this cam with a set of ls6 ported heads right now without a tune. Most of my mileage is city driving. The cam behaves pretty damn good without a tune. I went from about 230 miles a tank city driving to about 200 after the cam, and of course thats with driving the **** out of the car.
Old 03-14-2006, 08:26 PM
Louie83's Avatar
That doesn't sound too bad. I want the cam just being sure that I won't regret it later since I drive the car about as much as my "daily driver".
Old 03-15-2006, 09:46 PM
red01z28's Avatar
you wont regret it i daily drive mine with a 4000 stall and ms3 its great with a tune i get around 220 miles to a tank of gas you will be fine with a 6 speed it pulls like a monster up top
Old 03-16-2006, 04:48 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Go big or go home!
Old 03-16-2006, 07:53 AM
35thls1ss19's Avatar
Originally Posted by orangeapeel
Go big or go home!
thats the same thought i had when i bought my cam
Old 03-16-2006, 12:00 PM
yeah i see it just like orangepeel and 35thls1ss19, if you get a cam might aswell get a big one b/c your getting a cam for power and you know for sure the MS3 will give you that power as proven on texas speeds website with stock heads made 55+ horsepower from the MS3 alone.
