Who's ran the B1/T1 cam with LS6 springs.
Old 03-13-2006, 11:05 PM
Studytime's Avatar
Default Who's ran the B1/T1 cam with LS6 springs.
Just curious if anyone has ran the lunati/mti 221* .559" lobes with the late model LS6 springs. They can accomodate the lift, but open pressure may be too low. If you've ran this combo did you experience valve float, and if so what RPM?
Ben T.
Old 03-14-2006, 06:47 AM
Hardtop's Avatar
I wouldn't run LS6 springs with either of those cams. I'd run 918's at least.
Bruce
Old 03-14-2006, 07:53 AM
custom 68's Avatar
good question I too have a set of the "orange" springs that should be good to .580 lift anybody done this or simular?
dave
Old 03-14-2006, 08:46 AM
Kraest's Avatar
I'd run aftermarket springs... The PRC Duals are great.
In fact, I have a set of heads with assembled springs and titanium retainers for sale in the For Sale Section.
https://ls1tech.com/forums/lsx-parts-sale/465449-fs-ls1-241-heads-assembled-goodies.html
Mike
Old 03-14-2006, 05:02 PM
00T\A's Avatar
From everything i have heard an read i would not run the LS6 springs
with those cams.
Run the 918's. they are perfect for those grinds.
Old 03-14-2006, 11:35 PM
SUX2BU's Avatar
I have installed the newer LS6 springs with the T1 cam and it didn't work out. there was ALOT of valvetrain ticking. and valve float. swaped out to 918's = problem solved.
Old 03-15-2006, 12:04 AM
Studytime's Avatar
Cool. That's what I wanted to hear, or rather not hear.
Why was your top engine speed before they started floating?
Ben T.
Old 03-15-2006, 12:49 AM
SUX2BU's Avatar
Ben T.
it wasn't in my car i just worked on it.
