Valve train noise
Old 03-17-2006, 05:08 PM
jblackbird's Avatar
Default Valve train noise
I just had my MS3 Cam installed by a mechanic here in town, the car sounds awsome! My question is, Is it normal for the valve train to be tapping pretty loud? I did have the springs and push rods swapped out with the double springs and harden push rods. When I'm driving, it runs pretty smooth other than the tapping noise. At idle the tapping tends to go away. Is it tapping because of the new springs? or will it stop through time? Keep in mind this is the first time it's been cranked and driven since cam install.
Old 03-17-2006, 05:40 PM
4mula's Avatar
it sounds like a sewing macine correct??
more valve chatter after a valve train swap is normal.
Old 03-17-2006, 05:42 PM
RoastEmSS's Avatar
record a sound clip of it and post it on here, i wanna here that beast through duals
Old 03-17-2006, 08:08 PM
jub jub's Avatar
The answer to your question is "Yes!" These engines are noisy to begin with. Add a big cam and it's a virtual mechanical symphony of clickity clacking going on.
Old 03-18-2006, 06:56 AM
jblackbird's Avatar
I drove the car last night and it started tapping again and it did the usual by getting louder so I brought it home and turned it off, waited about 15 minutes and cranked it up and no tapping. I let it idle for a little bit and still no tapping. It only seems to happen when I'm driving, but the car drives smooth and excellerate fine, no vibrations or rough idle even with the loud tapping.
Old 03-18-2006, 07:33 AM
Race your car!
JL ws-6's Avatar
How many miles on your motor?
Old 03-18-2006, 07:56 AM
jblackbird's Avatar
96,000 miles on the motor
Old 03-18-2006, 08:53 AM
PREDATOR-Z's Avatar
I bet you have 7.40 pushrods, right??
Try putting 7.425's and you'll cure most of your tapping.
Old 03-18-2006, 05:11 PM
lowchevy2go's Avatar
how is longer pushrods gonna help? the lobes are taller on the cam, shouldnt the pushrods be tighter than with the stock cam already. Or am i an idiot..
Old 03-18-2006, 07:32 PM
BLUE99T/A's Avatar
The base circle is smaller.
Old 03-18-2006, 09:08 PM
mmorrison09's Avatar
lol i just had the ms3 installed 3 weeks ago and mine is doing the same thing and i have the 7.40 pushrods. The shop told me that the pushrods are barley to short and he has orderd me longer ones but there on backorder right now he said it was ok to drive the car like that just not to really get on it to be on the safe side, so ive been keeping it under 3 grand for 3 weeks now but i will update yall when i get the pushrods swaped out later
Old 03-19-2006, 09:28 PM
where can you find 7.425 pushrods. I cant find them
Old 03-20-2006, 06:29 AM
PREDATOR-Z's Avatar
I got mine from Thunder. Comp Cam.
Old 03-20-2006, 07:14 AM
AFTICA's Avatar
Mine are on backorder at Thunder. Thought I saw them in Summits newest book.
Old 03-20-2006, 07:17 AM
Ojustracing's Avatar
Try Byunspeed -------->>>>>>>>>>>>>>
He got me a set.
John
Old 03-20-2006, 06:39 PM
mine our on backorder at texas speed shop.
Old 03-22-2006, 06:22 PM
Robinator's Avatar
why doesnt TSP sell 7.425's with that cam? sounds like a few people have run into this problem. You spend the money, shouldnt you get the right parts that work properly?
Old 03-22-2006, 08:02 PM
well the 7.400 will work just alot more valvetrain noise, the 7.425 will cut the noise out alot is what ive been told. but yes i wish tsp would of let me know this when i ordered my cam package from them.
