ARP bolt torque with 30w oil???
Old 03-18-2006, 04:29 PM
LS1FIRE's Avatar
Default ARP bolt torque with 30w oil???
What is the torque with 30 w OIL for ARP bolts? Crap i got ARP thread sealer not assebly lube.
Old 03-18-2006, 04:33 PM
Valkyn's Avatar
It is like 90ft -lbs, but i wouldnt do it.
I was using oil while i was torqing my head bolts down, using their torque specs, and one broke. Had to pull the head back off and get the broken piece out, send it to them, then wait for them to send me a new bolt.
I used formagasket the next time.
Old 03-18-2006, 05:00 PM
LS1FIRE's Avatar
Anyone else ?
Old 03-18-2006, 05:08 PM
Old Geezer's Avatar
Question I think..
That if you look at the tube, you will see that it may have the lube in the sealer.
The tube I have, is marked pt# 100-9904.
Old 03-18-2006, 05:10 PM
kenp's Avatar
I believe it's 75 lb/ft with moly lube and 95 lb/ft with 30 wt oil.
I'm looking at the box my 12 pt studs came in and the additional torque with 30 wt oil is from 26% to 28% more than the moly lube spec.
Old 03-18-2006, 05:18 PM
LS1FIRE's Avatar
The tube i have also says 100-9904 am i good to go? It says in the instructions in the back that it can be used for head bolts
Old 03-20-2006, 02:40 PM
LS1FIRE's Avatar
Here are the correct torque specs for 30w oil for ARP bolts. I Called them and got the info from them. Big bolts 10 of them 28ftlbs 56ftlbs 85ftlbs. Small bolts 9,18,29Ftlbs
Old 03-20-2006, 02:57 PM
jub jub's Avatar
That's weird. I just put a set in and my instructions stated 65 for the molly lube and 70 with 30 weight. Go figure.
Old 03-20-2006, 03:01 PM
LS1FIRE's Avatar
I dont know man. I just got threw talking with ARP tech line and gave me this info. For part number i think 134-3609
Old 03-20-2006, 04:47 PM
cantdrv65's Avatar
Post
I used motor oil on my ARP studs and torqued to 75ft lbs. No problems.
Quick Reply: ARP bolt torque with 30w oil???
