How much HP gain from raising compression?
Old 03-21-2006, 03:07 PM
TINKRD's Avatar
Default How much HP gain from raising compression?
Say I have a Forged H/C motor running stock compression.
How much would I gain if I were to pull the heads, mill them down and bump compression to 11.5-12:1.
Next question, Say I've got a 200 shot of N20. Would that be too much for that high of a compression?
Car already has ARP Head bolts and Cometic Gaskets.
Old 03-21-2006, 03:24 PM
SideStep's Avatar
Approximately 2% for half a point… You really need to find out what your DCR is and what it will be to find out if it will run on 93 octane...
Old 03-21-2006, 03:31 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Dynamic is the better of the 2. Good job SideStep.
Old 03-21-2006, 03:33 PM
TINKRD's Avatar
Dcr???
Old 03-21-2006, 03:34 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Dynamic Compression Ratio
Old 03-21-2006, 03:37 PM
TINKRD's Avatar
hmm...found a calculater but dont know all the #'s to put in... any help is appreciated guys. just trying to get some insight.
Old 03-21-2006, 03:39 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
what is the link to the calc?
Old 03-21-2006, 03:40 PM
TINKRD's Avatar
http://www.rbracing-rsr.com/comprAdvHD.htm
Old 03-21-2006, 03:42 PM
TINKRD's Avatar
i've got Crower 6.125 Length Rods, Diamond Piston w/ a 2cc valve relief, stock 346 crank.
5.3L heads that are already milled .15. I cant remember what the intake runner size is:dunno:
Old 03-21-2006, 03:44 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Who put together your heads?
Old 03-21-2006, 03:45 PM
Viper's Avatar
https://ls1tech.com/forums/advanced-engineering-tech/467109-how-figure-optimum-dcr.html
Old 03-21-2006, 03:46 PM
TINKRD's Avatar
They're TEA Heads. Stage 1.5 5.3L, 2.02 int/1.55exh
Old 03-21-2006, 03:50 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
well the valve relief will take a tad bit away from what you had to start with.
Old 03-21-2006, 03:51 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Nitrous enjoys the higher compression.
TINKRD's Avatar
yeah, the shop that built the short block for me said they ran it through a calculator, and i'm at 10.85:1 right now.
Old 03-21-2006, 03:56 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That is what I am at as well in my Z28 with forged parts and diamonds with -2cc's.
Old 03-21-2006, 03:57 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Whatever your cam is and how much you are wanting to shave off the heads will need to be determined with PTVC. And the reliefs will help you ouot in that arena as well.
Old 03-21-2006, 04:01 PM
TINKRD's Avatar
i've got the MS3 in the car right now.
Old 03-21-2006, 04:05 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Ok, so you have a big cam that will enjoy having the hose on it. Im not sure what would be a safe bet for a 200 shot on those heads wihtout physically checking. you probably can take a tad more material off, but it might be more trouble than it is worth. Just get a tornado and stuff it in the bellow and call it a day.
Old 03-21-2006, 04:08 PM
TINKRD's Avatar
oh snap, i'm all over that tornado.
Quick Reply: How much HP gain from raising compression?
