Oil Pressure?
Oil Pressure?
I just put an ls6 manifold on my 2000 T/A amd the oil pressure gauge jumps up past 80 and stays till i turn the car off and then it goes down to about 60 when the car turns off. I was wonding if i broke the oil pressure sensor when i was doing the swap or something.
I agree, I did the samething. If you turn your car to the on position (don't start the car) and the needle immediately goes past 80 then you have either a disconnected sensor wire or you broke the actual sensor, or it is just loose. I bought mine at Napa for about $32.00 (I think).
anybody know of any way to keep the EGR from seting a code because i took mine out and now it has set a code. Is there like some kind of resistors you put in there or something?
tune that **** out... and yeah you prolly broke the sensor... i did this weekend
Anyway reach beind your intake and feel around for a cylindrical thing... if you find it and can move it you broke your oil pressure switch... congrats
Originally Posted by RobLS1
ok im not pulling that back off that was a pain in the *** for me to do the swap no room to work
Originally Posted by WhiteRhino
You should either fix it or put a new oil pressure switch in somewhere.There's a couple of places to tap into.I dont think that not having a pressure gauge is a good idea!Oil pressure is one of the most important things to monitor.Just my .02 cents!
where is some other places to tap in at?
I seen someone said to do it with the intake still on.Some people dont have that kind of patients to work back there like that.Its alot easier to just pull the intake.
