Do i have to re-balance my rotating assembly?
Old 03-22-2006, 06:53 PM
5.3litre's Avatar
Default Do i have to re-balance my rotating assembly?
Ok i bought some lunati rods and some diamond pistons along with a used 6.0 crank and i had everything balanced. Now i have to switch pistons cause i need to get low compression diamond pistons for a turbo i want to run. So when i get the new pistons do i have to re-balance everything or what? Also on the motor im building i lost the oil pump bolts and i need the bolt that holds the pick-up tube to the oil pumo. where can i buy these bolts?
Old 03-22-2006, 07:35 PM
fast377's Avatar
I would definately have the motor balanced again...especially with forced induction. You could probably score the bolts from the dealership.
Old 03-22-2006, 08:32 PM
n2o junkee's Avatar
yes you do. even though the factory says the exact weight is checked before put into boxes there can always be a mistake
Old 03-22-2006, 08:37 PM
5.3litre's Avatar
so i need to re balance the crank, rods, and pistons all at one correct?
Quick Reply: Do i have to re-balance my rotating assembly?
