0.040" Thickness head gasket options?
In a few weeks I'm going to be helping a buddy install my old AFR 205cc heads on his 03 Vette. I've been doing some research on head gaskets looking for an alternative head gasket with a compression thickness around 0.040" that is cheaper than Cometics. Does Fel-Pro or another manufacturer have a 0.040" head gasket for a stock bore LS1 that is reasonable $?
Originally Posted by mr2guru
haha... maybe if you seperate the layers.....
GM MLS either 5.7 or 6.0 are both .060 compressed.
I think I had a brain fart. I really don't know what the hell I was thinking
Nate
UNDER PRESSURE MOD
For some reason, I thought the factory GM gasket for a 2000 (standard graphite, NON MLS) had a compressed thickness of 0.054. Maybe I'm wrong. I have a ticking sound coming from #7 and think it might be a lifter, so if the heads have to come off, I want to go with a slightly thinner head gasket to get a better quench area.
A quick question, stock bore is what... 3.989 or something like that? Why does summit only list 4.000 and 4.060 as bore options for gaskets?
Thanks guys.
Thanks guys.
