F13 cam install !!.. help..!!
well im about to install an f13 on my car and i was wondering since my car hit 70 thousand miles i wanted to replace the oil pump.. should i get the regular ls6 pump or the HD one from slp or any other considerations. thanx for the help
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I would check with SDPC or Thunder. All the sponsors to the right are a good choice to pick up one. I think that you will be just fine with the LS6 pump. Your not looking for 550+ rwhp are you? That would determine what route you should take between the 2. What is the year of your car?
I hate to be the bearer of bad news but before you button up your engine I would call Futral and make sure you didn't get one of their "BAD" cams. Just trying to save you some major grief in the future. Other than that it is a great performing cam and I loved mine until I heard the news, will probably replace with same exact cam.
