Engine dies out
Old 03-25-2006, 08:07 PM
CRZYPWR's Avatar
Default Engine dies out
I have this problem. It only happens from time to time. When the car idles, the rpm starts to jump a little about 500 to 700, then it starts to go from about 800 all the way down to 300, jumps up and down, and if I wont give it a little gas , it will die out after about 5 secs. I replaced MSD wires and NG spark plugs about 2 years ago. What could be the problem ?
Thanks
Old 03-25-2006, 08:40 PM
CRZYPWR's Avatar
Anyone ?
Old 03-25-2006, 11:50 PM
LS1powerhouse02's Avatar
what mods are done to the car? If you have done anything major (headers, eliminated cats, cam, etc.) to the car you will need a tune. Without a tune your a/f ratio will be all over the place making the car run rough. Another thing it could be is 02 sensors taking a **** on you. I would double check for either of those first. Also....is it throwing any codes?
Old 03-26-2006, 02:01 AM
heavymetals's Avatar
Check for air leaks.
Cracks in air to manifold or to MAF cause that kind of stuff.
Old 03-27-2006, 12:01 PM
CRZYPWR's Avatar
See the car started doing it after I did the trans on it. I didnt have any problems with it before. As far as codes.. hell yeah. YOu might be right with the O2 sensors. Ill check that.
